Brief Description: Mark Locations For Rivets; Drill & Cleco Rib to Ti
I marked the rivet locations on the fiberglass tip while it was still on the bench. The marks are 5/16" from the edge with 1.5" spacing top and bottom. Once everything was marked I clecoed the tip back onto the wing and then used side clecos to hold the rib in place while I drilled all of the holes for the rivets.
Rivet locations marked - 5/16" from edge and 1.5" spacing
Right tip clecoed to wing and rib side clecoed to tip
Right wing tip rib drilled and clecoed to fiberglass tip
