Dan's Web Site
Date:  3-7-2012
Number of Hours:  0.50
Brief Description:  Trim Fiberglass Tip for 1/4" Clearance From Ailero
The plans indicate there should be 1/4" clearance between the wing tip and the aileron. I had about 1/8" clearance so I removed the wing tip, marked another 1/8" to trim, and then used the dremel with a cutoff wheel to obtain the needed clearance. I then sanded the edges with a sanding block.
Right wing tip marked to provide 1/4
Right wing tip marked to provide 1/4" clearance from aileron
Right wing tip trimmed to provide 1/4
Right wing tip trimmed to provide 1/4" clearance from aileron
