Dan's Web Site
Date:  7-16-2011
Number of Hours:  1.00
Brief Description:  Bolt Short Left Aileron Pushrod to Bellcrank
Once the length of the short left pushrod connecting the aileron to the bellcrank was set to its proper length and the jam nuts were tightened with high strength loctite it was time to remove the bellcrank jig and bolt the push rod to the bellcrank. Both ends torqued and sealed. The first pushrod is in place!
Short left aileron pushrod bolted to bellcrank
