Brief Description: Notch Rear Window and Install for Drilling
I jumped back to working on the aft window next. It's a tight fit trying to coax the plexiglass under the top skin all the way around the aft edge. The initial fit wasn't too bad. I needed to notch the lower front corners to fit around the large rollbar attach brackets. I also had to notch the aft edge approximately 3" in length to fit around the top center support channel where it attaches to the F-706 bulkhead. Once the notches were made, the rear window fit perfect!
Need to notch the front lower corners and around the top aft center support channel
