I finally decided the best place to install the fuel flow sensor was between the gascolator and the engine driven fuel pump. I had ordered the appropriate length teflon hoses from Airwolf and finished up the fuel system today. I decided to run the main line off the outboard side of the gascolator to keep the fuel lines as far away from the electical components under the battery (relays, shunts, etc) as possible. The main fuel and primer fuel lines were then secured with adel clamps. The fuel system is finally complete!
Fuel flow sensor connected between gascolator and engine driven fuel pump - primer line underneath
Primer and main fuel lines from gascolator to engine
