Brief Description: Secure Left Side Primer Lines with Adel Clamps
I spent most of today securing the stainless steel primer lines and brass T fittings using adel clamps. This was very difficult because of the tight quarters but I was eventually able to work my way around the primer system and secure everything.
The primer lines were secured to the cylinders with special Lycoming clamps that I purchased on Ebay. I also used spiral conduit wrap around the lines to prevent chafing against the intake manifolds and against the engine casing and engine mounts. Nothing is actually touching but the primer lines run very close to these and I wanted to protect the lines against any potential chafing. I doubt the lines will actually move much since they are now very secure with all of the clamps in place.
Here are the pictures of the primer lines secured along the left side of the engine.
Brass T between Cyl's 2 & 4 secured with adel clamp
Brass T at back of engine secured with adel clamps
