Brief Description: Match-Drill F-644 Ribs to Spacers/F745 Ribs
To match-drill the short F-644 ribs to the spacer blocks and F745 ribs I had to lift up the top skin and reach in with the drill. All of the holes in the ribs/spacers are now drilled. I temporarily inserted some bolts to hold everything in place.I decided not to install the canopy quick release mechanism. Too complicated, too much weight, takes up too much panel space, and I'll never be wearing a parachute. I'm just going to bolt the canopy hinges to the ribs/spacer blocks.
Left side - F-644 rib match drilled using F745 and spacers as a guide
Right side - F-644 rib match drilled using F745 and spacers as a guide
