Brief Description: Install Left Side Cylinders 2 & 4 Brass T Fittings
My next step was to connect the cylinder # 2 and #4 primer lines to a brass T fitting and then install a stainless steel line that wraps from the #4 cylinder around the back of the engine that will eventually connect to another brass T fitting from the right side #1 and #3 that will then connect to the gascolator feed line.
Cylinder #2 primer line connected to brass T fitting
Cylinder #4 primer line connected to brass T fitting
Brass T fitting from cylinder #4 to the back of the engine
