Brief Description: Bend / Install Stainless Steel Primer Lines 2 & 4
Next I used the copper template lines to bend the stainless steel primer lines for left side cylinders 2 and 4 and installed them on the AN4022-1 primer discharge nozzles.
Stainless steel primer lines for cylinders 2 and 4 bent to match copper template lines
Stainless steel primer lines installed on left side cylinders 2 and 4
