Larry Winger's 601XL Project
Date:  11-12-2012
Number of Hours:  0.75
Brief Description:  2 - Connected RS232 #1 from V10 to Voyager
This allows you to set your radio frequency from the airport database in the EFIS. If you press "0" you get a list of the nearest airports. When you select one, by number, you are given a list of all related frequencies. By number, you select the frequency you want (tower, ground, ATIS, etc.) and it is immediately put into the V10 comm radio as the active frequency. Very handy. I also moved the AHRS power wire from a fuse to the secure power output on the back of the Voyager.
