Brief Description: Located and drilled nose rib 1 angles
With plenty of very careful measuring, I was able to locate both angles on nose rib 1. In talking with Roger, we determined that I could place the long angle on the outboard side of the nose rib to align with the bolt holes, even though that meant having limited space in which to rivet to the wing root doubler. I was quite careful to maintain edge distance, but still managed to get 4 rivets through the parts, plus the bolts. It is not going anywhere! The other side was lined up and will have staggered rivets through the short angle on the inboard side, since it has a wider flange than the other flange
The outboard angle drilled for rivets through the rib and into the wing root doubler
