Once I determined the best angle for for oil system sandwich adapter, I torqued it to 35 foot pounds. I routed the oil lines in such a way that I could remove the oil filter without having to move the lines. As you can see, I used three 120 degree fittings and one 45 degree fitting coming from the lower port on the cooler.
