Brief Description: Disassembled, deburred & primed elevator
During disassembly, I used an idea I picked up from the Zenith list. I used my engraving tool to lightly mark mating parts. Even through primer you can usually see your marks. It beats what I have done in the past (nothing), which makes you try to keep things laid out on the table in some order and hope that you didn't switch things inadvertently. Using this technique, everything came out fine. Lots of holes to deburr, but as usual the priming went pretty quickly.
