Brief Description: Drilled center ribs to spar, L angle and deburred
I finished the assembly of the skeleton by drilling and clecoing the center ribs to the front spar. I also attached the standard L angles to the ends. I then deburred the front spar and attached parts. This means my next step is to clean, prime and rivet the stabilizer skeleton. Hopefully the rivets will arrive tomorrow. By drilling 4 holes instead of 5 in a structural part, I lost 5 days and about 8 hours remaking the front spar. Lesson learned: read the plans, read the plans, read the plans.
