Larry Winger's 601XL Project
Date:  7-26-2006
Brief Description:  Second attempt at rib
Spent a fairly frustrating evening reviewing relevant portions of the scratch-building DVDs and then making a sub-standard rib...again. My problem seems to be that I'm leaving too much material at the end of the rib, leading to creases. I'm also not clamping the nose firmly enough to keep the material from entering the space between the form blocks.
