Larry Winger's 601XL Project
Date: 12-5-2008
Number of Hours: 3.75
Brief Description: Fabricated vertical tail leading & trailing edge s
After a trip to Aircraft Spruce for more .025" sheets, I laid out, cut and bent the vertical tail trailing & leading edge skins. When I made my 601XL rudder, I did it using the prescribed .016" metal, and every rib line was pronounced as the skins pulled in to meet the ribs, producing a slight creasing. After checking the Matronics archives, I saw that a number of builders (and apparently AMD) have gone with skins that are .025' thick. The weight premium on the rudder may be as much as a pound, but I think it will be worth it to have a more substantial control surface, if for no other reason than aesthetics. In the last picture below you can see where I marked the leading edge (nose) skin for eventual trimming. This is approximate, per the plans, and must be cut upon installation of the rudder to miss adjacent parts.
Vertical tail trailing edge skin
Leading edge skin
Closeup of probable trim line per the plans
