Larry Winger's 601XL Project
Zodiac CH 650
6W1-1
More work on flap ribs
I initially made two identical rib blanks, bent one into a completed rib (to check for accuracy) and then used the other blank as a template to lay out the other ten rib blanks needed. Then I trimmed all the blanks and drilled the relief holes.
One rib and 11 blanks
Zodiac CH 650 Home
3152
284
231
293
915
294
Planning
Total Hours
1103
Work Area
