Brief Description: Finished stabilizer front spar assembly
Checked and re-checked the position of the plywood spacer, then clamped, drilled and clecoed the front spar attachment doublers. This set the outer edge for the actual front spar attachments which extend downward through the stabilizer skin when completed. Clamped, drilled and clecoed them as well, completing this part. Only drilled #40 pilot holes and won't enlarge them until later.
