Brief Description: Connected panel and control cables
From beginning to end, this was a day about making the instrument panel feel at home -- finally. I first reconnected the throttle, mixture and carb heat controls. I then reconnected all the wires that had previously been attached to the center support. The most challenging were the relay deck wires because of small screws and awkward angles. Finally I made connections that start at the panel and center support and go to other places. I treated myself to a light show at the end by firing up the panel. A thing of beauty!
It's alive
Pitch trim indicator, Garmin GMA 240 audio panel and MGL XTreme EFIS all working
MGL Voyager EFIS and Garmin GTX 327 transponder powered up
