Larry Winger's 601XL Project
Date:  3-2-2011
Number of Hours:  1.50
Brief Description:  Removed seat panels and arm rests
With the modifications that were required for the seat panel / arm rest area, I decided my best approach was to remove everything and be able to work in the open. The first problem I faced was that the rear bottom of the seat panel is riveted into the gear leg channel, and the rivet head were covered by the main gear. Once again, I removed my main landing gear. After that it was simply a matter of de-riveting everything that held the seats together. This is all for the purpose of replacing the .025" L angles with .040" L angles. In addition, I needed to replace the vertical supports around the spar access holes to the thicker size and extend them from spar down to the gear channel. Because I had already installed nutplates in all four corners of the access hole, that it what finally convinced me to disassemble everything. What fun.
No place to sit
No place to sit
