Darrel's Kitfox - SS7
Date:  8-15-2023
Number of Hours:  6.30
Brief Description:  Wing panel attach brackets
Completed assembling and riveting the wing center section.
Then fitted the outer wing panel mounting brackets. They have to nest in the radius of the angle aluminum spar cap; additional material needed to be removed from the bracket to ensure a non-interfering fit in the cap.
Riveting the caps is complete
All bolts torqued
All bolts torqued
Material below the line needs to go
