Darrel's Kitfox - SS7
Date:  6-24-2023
Number of Hours:  3.50
Manual Reference:  None
Brief Description:  Fitted the skins to the HS and fuselage
After verifying the rear HS spar was straight, fitted the inside edge of the HS skins to the fuselage. An iterative process to say the least but when all was said and done the fit was there and the spar was still straight
Set up for keeping everything straight
Before the fitting exercise
After fitting
After fitting
