Brief Description: Finished riveting nutplates and connected subpanel
I finally finished riveting all the nutplates and connected the frame angle to the subpanel angle to see if the panel plates were flush to the subpanel. They were!!
Everything now has to be disassembled to get the frame and subpanel into the airplane. I will reassemble the frame and connect it to the panel ribs and deck brackets at the top and the angle brackets at the bottom which are now just clecoed to the fuselage side skins. I will then assemble the vent outlets to the vent holders and clamp the fuselage angle brackets to the vent holders and match drill through the brackets and side skins. These brackets hold the subpanel firmly to the side skins. I'll do all that tomorrow.
Frame stiffener screwed to the subpanel stiffener.
Frame connected to the subpanel. (Note: the AP module will be level with the EFIS when installed!)
