The Dynon D180 and D100 EFIS's need connections to the static, pitot, and AOA tubing to get the pressures for displaying the altitude, airspeed, and angle-of-attack indications on the EFIS. I had already installed the tubing behind the subpanel and it was a matter of just inserting the tubes into the connecting fittings at the back of the Dynon boxes. I made sure to cut the tubes square with a tubing cutter.
I added a couple of zip tie mounts to better hold the pitot and AOA tubes more secure to prevent them from rubbing the top fuselage skin.
The tubing inserted to Dynon D180.
Tubing inserted to D100.
Connection to airspeed switch for TCW's Intelligent Flap Controller.
