KENNETH T.'S WEB SITE
Date:  7-9-2011
Number of Hours:  2.50
Manual Reference:  Aveo manual
Brief Description:  Olive can landing light experiments.
After playing with the wingtip cut-out and using a can of olives that approximates the diameter of the Aveo 6-in-1 landing light, I still can't quite figure how I will make the installation. I've come to realize that the light cylinder will have to be recessed into a hole cut into the 120 degree face of the cut-out. Some kind of cradle or fixture will have to hold the light and allow an up/down adjustment. I don't know if there is enough room under the lens. The clearances will be close to the lens cover.
Surely someone has already figured out how to do this, although I haven't found that person yet! I'll worry about this when I return from our Russian river cruise vacation.
The can almost touches with 10 degrees up.
Easily clears the lens when straight ahead.
Clears lens by about 1/4
Clears lens by about 1/4" when adjusted down.
