Brief Description: Removed foam adhesive from zip tie mounts.
I tried to remove the foam adhesive from the zip tie mounts and found that no tool would do the job except my thumbs and fingers. I tried soaking the mounts in acetone and then alcohol with negative results. Just made a mess and still had to use my thumbs. By the time I had taken off the adhesive on a dozen mounts, my hands were sore and my arthritic fingers and thumbs were hurting. There must be a better way!
I'll think about this for a day or two and let my hands recover.
