Brief Description: Wired flap motor and did continuity testing.
The flap motor wires had already been pulled from the Flap Controller and were just waiting to be connected. I had bought a two pin Molex connector and planned to use it on the flap motor connection, but I held off and wired using butt connectors instead. I decided to leave the wires as long as possible untlil I'm sure that I won't need to reroute the wires from the tunnel.
We did some continuity testing today to be sure the wires that we had completed had good crimps and were routed to the correct terminals. Everything seemed to check out OK, thank goodness!
Copilot stick temporarily installed to measure the blue cable for trimming.
Flap motor wires were butt crimped and zip tied to stickon holder.
