Brief Description: Reinstalled Safety-Trim and Flaps Modules.
I removed the TCW Technology Safety-Trim and Flaps modules from the seat ribs because the 5-point Hooker harness required Van's crotch strap kit to be installed. Of course the modules had been installed and would have interfered with the crotch strap kit, therefore, a new location was needed for the module. After spending a couple of days thinking about a new location, I finally decided the middle rib forward of the subpanel and behind the firewall would work OK.
I had to be able to adjust the speed screws on the safety-trim speed adjusting screws, so I had to put some spacers on to allow a screwdriver to clear the angle on the middle rib. I mounted the flap module back-to-back with the safety-trim module and had to custom cut the length of the screws on the forward ends to allow the harness D-sub fittings to fit. I think this will be a better position for the modules in the long scheme of things since the wiring to the buses and the terminal blocks will be simplified, I hope.
I also made measurements for installing the Infinity grips to their respective sticks.
Safety-Trim module installed with plastic spacers.
Flap module installed back-to-back on the other side of the rib.
Deciding on the twist angle of the grip to allow a straight wrist postion.
