Brief Description: More switches wired including the fuel boost pump.
I decided to wire the fuel boost pump which meant I had to figure out how to route the wires. Since the pump is on the centerline it was a no-brainer to run the wires forward to the FW then up the left angle to the left foward top rib and run it back through the subpanel hole to the switch. The ground wire followed but stopped at the FW ground plate. The power to the switch comes from the Main Hot Bat Bus which is mounted to the right forward top rib. A wire was routed down the rib and across the bottom of the subpanel and then to the switch.
The next wires to be wired will be the power wires from the Main bus to the nav/strobe and taxi/landing light switches. Onward and one day upward!!
Fuel boost pump wired for power and ground.
The two red wires in this bundle go to boost pump switch.
The power for the boost pumps comes off the Main Hot Bat Bus (red wire).
