Brief Description: Started wiring switches on the switch panel.
Started wiring the switches today. The first switch to get a wire from the Main bus was the Main Master switch. The alternator field wire goes from the Main bus to the # 5 terminal which will make the connection through the # 4 terminal and will later be wired to the alternator.
As my buddy John says, from here on out it is "Monkey see, Monkey do" hoping to catch any errors to the schematics and switch wiring diagrams. I've already corrected some errors and it looks like it will be a contiuous correcting of the computer drawings as I go. Did someone say this was going to be easy? I'll shoot him when I find him!!
Wires starting to sprout on the main bus!
Wires passing behind radio stack on the subpanel and going into bushed hole to the switches.
Wires coming thru subpanel and attaching to tabs on switches.
