Brief Description: Crimped fat wires for electrical system.
Using the new crimper, the fat wire fabrication went into high gear. I made the following cables: Main fuse block to shunt (FW pass-thru), Aux contactor to Master contactor (FW pass-thru), Main battery to Master contactor, and Shunt to Starter contactor. The Aux and Main batteries are connected through the Aux contactor.
The terminals were crimped and then I heated them and let solder seep into the open end of the B & C (Amp) terminals. The idea is to get a better electrical connection than the crimping alone.
Tomorrow, a cable to the Main Hot Battery Bus and a cable to the E-Bus Alternate Feed Relay.
Fat wires to the shunt, master contactor, starter contactor, and main battery.
Aux contactor on inside of FW connected to Master contactor.
