Brief Description: Installed fuse blocks and Schottky diode.
I've got brass machine screws on order from McMaster-Carr to install the fuse blocks but they haven't come in yet. So I decided to use some cheap #10 screws to go ahead and install the fuse blocks and will change out with brass screws when they arrive.
The Schottky diode from Aeroelectric arrived so I decided to install it on the rear subpanel between the the main buss (on the right) and endurance buss. All the screws are brass and the subpanel is 0.040" thick and serves as the heat sink for the diode. The main battery wire will probably come through a hole in the subpanel on the right of the main buss. The wires connecting the diode to the busses will only be about 3" each. Another hole to the left (I think) of the endurance buss will allow most of the wires from the busses to go under and behind the middle stack and come back though a hole on the left side where most of the switches are located.
Fuse blocks installed with cheap machine screws. Will replace with brass screws.
The Schottky diode is on the rear subpanel between the fuse blocks.
