Brief Description: Riveted the drop down fuse block panel parts.
The riveting of the panel went quickly using the pneumatic squeezer. All the rivets used were flush -3 rivets. The pictures were taken with piano hinge clecoed to the forward subpanel since the panel will be removed to add the fuse blocks and Adel clamps. Until I actually start wiring, I really won't know for sure where the wires will run. I have my schematics on paper but they won't wire for me. There will be quite a few holes drilled and bushed through the forward subpanel. Oh, well, I still need to order some more parts! And as my buddy John says, once you start wiring, it's monkey see - monkey do!
Overhead view of panel riveted and locked to brackets.
View through the right side of the instrument panel.
View in drop down position under the switch subpanel.
