Brief Description: Hose and wire routing iterations.
Trying to figure out where to route hoses and electrical wiring is a repetitive process. Go this way and you block that, etc.! I'm taking my time while visualizing how it would be later when maintenance is required. The mixture cable had to be slightly rerouted under the subpanel to give enough length to reach the injection servo bellcrank. I had to buy a new oil cooler return hose because it was too short. All fluid hoses were fire sleeved which meant I had to order it and more Adel clamps from McMaster Carr, etc. On and on, one thing after another.
Magneto ignition wires on the bottom left.
Magneto ignition wires on the top right.
Mixture & prop cables, fuel pressure hose, and ignition wires.
