The gasket that Whirl Wind forgot to put in the box came today after about a year and a half wait since the prop and governor was delivered. No problem, since I had been fumbling with the baffle parts, installing the governor will be a relief.
The studs on the accessory case took 5/16 x 18 nuts which are the same as for the exhaust system. I had to go buy some nuts and washers to install the governor since the only nuts that I had were already devoted to the exhaust. The fuel to go buy the nuts and washers cost more than the parts. Had to do it, aargh! Once home with the parts it went on quickly.
