Brief Description: Sanded rear skirt and touch-up pinholes with fille
After letting the expoxy filler cure overnight, I sanded the filler off to check how well the recessed washers and rivets looked. Sure enough I realized that I needed to add more expoxy filler to completely cover the washers and fill some pinholes. I hope this will do the trick so that I have a nice smooth surface to prime and expoxy.
Tomorrow, more sanding and priming, I hope.!!
Sandpaper in my right hand a vacuum in my left hand.
