It took quiet a long time to mark the hole patterns on the side skirt. I decided that I would drill both side skirts at the same time so I double checked the measurements and then had Charlotte check them just to be sure they were right. After triple checking the measurements, I clamped both side skirts together on the workbench and proceeded to drill the holes. The drilling went quick and then I deburred with Charlotte's help. Trying to figure out which holes will be enlarged and countersunk or dimpled is not obvious from the plans. It would be easy to screw up the skirts because the manual seems to want you to figure it out for yourself at this point. Oh, thanks!!
