Brief Description: Drilled holes for canopy deck bracket to hold pane
Today I drilled out 10 holes that were supposed to be match drilled. The brackets that hold the instrument panel to the canopy decks should be match drilled to the decks, but that was impossible to do with the forward top fuselage skin clecoed. I, therefore, marked the front of the panel with my blue sharpie. One line horizontal on the forward canopy deck and one line vertical. Then after unclecoing the panel, I used the sharpie to mark the bracket holes that had already been drilled during fabrication. I then removed the skin and drilled the holes. Hope they all line up ok.
