Brief Description: Drilled rudder/brake pedal angles and parts.
Charlotte had already rounded up the parts for the rudder/brake pedals and had them positioned on the work bench for me. Love my partner (wife)! All I had to do was decipher the drawing, drill some holes in the angles and parts. Easier said than done. The angles are all the same size and I drilled a couple of holes in the wrong spots until I realized I needed to mark up/down and left/right. I knew that, but I got in a hurry and screwed up as usual. You almost need to study the drawings to memory and then check again before drilling or cutting. I must constantly remind myself of that. Anyway, I finally got everything drilled and clecoed together. It just takes more time than you think it will.
Tommorrow I'll machine countersink the pedals and the side brake plates for the AN426AD4-6 flush rivets.
