Brief Description: Fabricated supports for cables.
Today I temporarily installed the prop and mixture cables to determine their routing to their respective eyeball FW penetrations. Both penentrate the FW on the left side per Van's drawings.
I fabricated two supports out of some scrap steel which were mounted to the rudder pedal support with #8 screws and nuts. Adel clamps support the cables which then pass through their eyeball penetrations. This arrangement will keep them out of the way for the cabin heat cable which also has an eyeball penetration at the bottom of the FW. Forgot to take a picture.
