KENNETH T.'S WEB SITE
Date:  2-12-2012
Number of Hours:  4.00
Manual Reference:  Aveo wiring schem.
Brief Description:  Wing wires attached to terminal blocks.
Today I cut the pulled wires to the correct length (I hope) and prepared them for crimping the faston terminals. I then crimped on the 1/4" faston terminals and attached them to the numbered block terminal tabs. Nothing difficult about this other than it was time consuming to put on the wire labels using heat shrink and the actual crimping. Slow and steady patience while doing this work was all that was required.
These wires should not have to come off the tabs unless the wing end was damaged or some other unforseen electrical problem. If the wing were removed from the fuselage these wires would stay connected but the root connectors would have to be disconnected.
Pulled wires connected to block terminal with  1/4
Pulled wires connected to block terminal with 1/4" faston terminals.
