Brief Description: Assembled and drilled frame then clecoed skin on.
Started the Vertical Stabilzer today. Charlotte helped me cleco the frame together then I dirilled it with #30 bit. We then clecoed the skin to the frame.
Read instructions and studied drawing. Clecoed the rear VS spar to the doubler. Clecoed the ribs to the front and rear spars. Drilled the spars, doubler and ribs to #30 size. Clecoed the VS skin to the frame with Charlotte's help.
