KENNETH T.'S WEB SITE
Date:  2-17-2009
Number of Hours:  6.00
Manual Reference:  Elec. Aileron trim
Brief Description:  Started installing Aileron electric trim.
Charlotte and I finished inventorying the small bag items and stored them on the peg board and in boxes under the work benches. I then started working on the electric aileron trim kit that I had almost forgotten. I wish I had installed it before installing the elevator pushrod because the tunnel area is small and with the pushrod there, it's going to be very tight drilling and working around it. Oh, well, dummy me, but I think I can do it.
I drilled the mounting block and bracket per the drawings and removed a couple of platenuts from the ribs on either side of the tunnel. Charlotte deburred and scuffed the bracket and I went to the paint booth (back yard) and primed it. I then assembled the control arm into the block and bolted it to the bracket. Enough for today.
Control arm bolted to bracket and electric trim motor.
