Brief Description: Started wiring the D180 EMS harness.
I started wiring the rest of the EMS harness today. I had previously wired the trim and flaps inputs to the D180 EMS. I wired to the avionics ground bus and routed harness wires to the ammeter shunt and to the fuel flow sensor. It's always a pain deciding where to route the wires, although I now have enough holes and paths to have a choice.
Tomorrow I'll make the connections although I need to order some #6 ring terminal connectors to wire the shunt. Always an order before completing what I want to do, Arrgh!! The #6 terminals are needed to fab the fuse links.
