Brief Description: Wired the 10K pot for HS34 audio.
Today I installed the 10K pot for HS34 audio output. I had to remove the two stereo pots that I had previouly installed, so I now have an extra hole in the subpanel that I can run wires through if necessary. Soldering took place up on the canopy rail so that I could see and reach the small connectors. I had previously measured out the wire lengths so that I could work with pot not connected to the subpanel. Soldering is not my forte, but I managed to get the wires connected OK. All the continuity checks were good.
I will reach under the instrument panel to adjust the volume of the HS34 audio output. Once set I shouldn't have to mess with it too often, I hope.
Looking aft, the pot is on the lower right (forward) side of the subpanel.
