Brief Description: Drilled the vent outlets with the receptacles and
Today I match drilled the vent receptacle with the vent outlet and vent hose adapter. This was nothing more than stacking the parts and then clamping them together. I used a #19 drill to match drill through the predrilled holes on the vent receptacle. The pieces will be held to a angle bracket that is riveted to the fuselage skin on both sides of the subpanel assymbly. Tomorrow I'll fabricate the angle brackets that hold the bottom of the panel frame to the fuselage skin and also make the brackets that will hold the subpanel to the fuselage.
The vent outlet was match drilled with the vent hose adapter through the predrilled vent receptacle.
