Bill & Brendas RV-8 QB
Date:  8-14-2011
Number of Hours:  3.50
Manual Reference:  8-46 dwg 76
Brief Description:  Front and back seat backs final assembly
1. Lightly sanded the primered parts from yesterday
2. Cleco together the front seat back and rivited together with AN470 rivits
3. Cleco the top portion of rear seat back and rivited with AN470 rivits. Used the pneumatic squeezer for most rivits but had to resort to good ole fashion bucking for the rest.
4. Cleco the completed top to the bottom seat back and rails and hinge. Rivited the hinge first using the squeezer and then bucked the top to the bottom following with bucking the side rails.Needed a longer rivit set for the rails. Need to order one. I did have a off-set one that was long enough to use though I don't like it as much as straight ones. I seem to mess up the rivit heads more often. But after a few re-do's on some rivits, the seat backs are complete.
Front Seat back assembly rivited
Top portion of rear seat back rivited
Rear seat back done-needs another coat of primer
