Bill & Brendas RV-8 QB
Date:  8-14-2011
Number of Hours:  2.75
Manual Reference:  8-47
Brief Description:  Flloor stiffners, aft control mount, Flap bearing
1. Separated and marked and polish 16 floor stiffners
2. Cleco the aft control mount into position and final drill to #12 the front two hole. Inserted an3 bolts to hold while I match drilled the aft 2 holes to same size
3. Edge polished the aft control mount.
4. Used my #8 nut plate jig to drill #40 holes for 4 nut plates that will attach the aft control mount. Drilled through the floor boards into the seat rib angles. The k1000 plate nuts will be rivited in later.
5. Marked for bolt hole locations in the nylon flap bearing block and then drilled the holes to #12 on the drill press. These need to be drilled out to #10 later when I can get the drill bit ordered.
6. Marked for corner angles on the blocks as per drawings and sanded down using the belt sander. This worked well.
#8 nut plate jig to drill for nut plates on aft control mount
Floor stiffiners
Floor stiffiners
Flap bearing blocks drilled and angled
