Brief Description: Trutrac roll sevo/ Instument panel-1
1. Got the roll servo and supplied hardware out for inventory. Studied the drawings some to figure out where it will mount. Looks like I will need to drill out a couple rivits for the bracket under the seat area. I then cleaned up the bracket edges and primered. I need to check more on the install position before I do any more.
2. Started the Panel. I clecoed the left and right sub panels together but offset by one hole so that there will be room for the panel attach flange to be drilled. Drilled all the flange holes and then un clecoed. Drilled the platenut rivit holes and deburred all. Machine countersunk all 70 holes for flush rivits.
