Re drilled the problem holes taht I had added some cloth and resin to on back side. I then top filled a couple of the holes with a flox and resin mix and scraped off excess. I can see from back side where I had drilled so should be able to drill a final time and have a clean hole and surface.
Added a layer of cloth and resin to the left skirt top front edge. Still working on increasing the edge distance in that area.
